Jacob
What goes around comes around.
Absolute nonsense - I've spent half my life working in old buildings being impressed the degree of skill and intelligence shown everywhere. Pre WW1, after that things go downhill.deema":2y3z4ikl said:......I’ve done enough doors in old properties to believe that most were fitted by people who had little if any skill.
Because labour was cheaper. The same job nowadays would be costly and we don't have the skills.It was standard practice to repair doors and frames by splicing in new pieces. Often the bottom of the frame rots out and new pieces about 2’ long are inserted over the years. This had nothing to do with preserving original fittings, but rather down to economics, it was cheaper to do!
AgreeWhat ever you decide to do, I wouldn’t be too hard on the joiner who installed the door.
Not true. Copying the old door is straightforward but requires a bit of skill, appreciation and the kit. It's being done all over the place but you wouldn't necessarily know because you can't tell (if it's done properly) whereas you can tell instantly when something has been replaced with something out of character, as we have hereIt was mission impossible to achieve perfection.
More nonsense. That's a classic and good quality door of its type and it appears to be in fair condition even after 100 years or more. It would have outlasted the door which has replaced itEqually I wouldn’t get too bleary eyed about the old door. It’s not a complex door, little moulding on it and flat panels would suggest it was ‘budget’ end. The ‘craft’ of how it was probably made and definitely installed is on display, and that which we can see was done with little to no skill!
PS Victorian 4 panel doors tended to be plainer detailed. The bottom panels are flush, which is better for weathering (more rain hits the bottom and no horizontal ledge or moulding for it to sit on) and because they are thicker - better for traffic - more impact likely at the bottom, boots, hooves etc. Sometimes made the full thickness of the frame . The mouldings are vertical and struck rather than stuck, which also weathers better. A 6 panel door, being fancier, would sometimes have glass in the top 2, bottom 2 panels same as above, 4 top panels with bolection mouldings nailed on - with the nails going into the stiles and rails not into the panel - so it can move free. etc etc they really knew what they were doing!
