February's Challenge, a Candlestick
Status
Not open for further replies.
Blister
10 Nov 2006
Boston Lincs
Candlestick to be a minimum of 20cm 8” tall and a maximum of 41cm 16” tall
( Excluding the candle )
One item per entrant
No Tea lights
No Candelabra
No segmented work
Any wood type
Any design
Texturing / piercing / coloring / carving / burning / natural edge ALL allowed
NO Critique or comments on any work until March Please, After the Judging and results.
Completed entry's ( 3 photos ) to be uploaded from 22nd Feb. up until 10pm on the 24th Feb, after this time the forum thread will be locked for Judging.
The Judge for February will be George Foweraker
The Judges decision is final
Please state item size, width and height and wood type if known and a little about how you made it and what finish you used ( this helps the judge )
Please post 3 images of your work
1 side profile
2 others showing close up details you want the judge to see
Image size please use image size 640 x 480 0.3 mp, same as January
Can you PM me when you have your project ready so I can mark you off the list of entrants
I look forward to seeing how creative we can be with this challenge.
Entrants list for February 2011
babylon355
Blister
Bodrighy
callumlovatt
cambournepete
chill
Chris357
Chrisp
clk230
como
Daven
dennisk
DougieH
duncanh
Dust Busker
Elaine
gus3049
Haldane
Hudson Carpentry
johnny.t.
Jonzjob
liamscanlan
loz
maltrout512
matmac
Melinda_dd
miles_hot
monkeybiter
myturn
not_simple_si
Oakbear
OldWood
Paul.J
philb88
Pvt_Ryan
RATWOOD
RO
Silverbirch
skeetoids
steve66
SVB
The Shark
TheTiddles
whacky
Wood spoiler
Made from Ash. 9" height by 1 1/2" wide at base. Roughed out using a 1/2" gouge then down to 1/4" gouge. The finer work and overall shape was done with the skew. The bowl gouge helped a little with the more cove curve. Sanded down to 240grit then burnished. 1 coat of Polyurethane satin varnish followed by a rub down with 0000 wire wool. Finished with 2 more coats of Satin PUV.
    94.1 KB
    70.7 KB
    43.5 KB
This is my first effort at turning a candlestick,and probably wouldn't have turned one hadn't it been for this comp :D
I tried to make this one look as if the unevenly turned balls are balancing on top of each other,which i hope i've achieved??
As allen wanted to see a candle in the sticks i thought i would oblige by turning one from Pine with some nylon string as a flame :D
The candlestick is turned from offcuts of Ash and Walnut,finished with Hard wax oil.
It measures 9-1/2" tall the stick by 2-1/2" dia balls.
Sorry about the poor quality photos, cant seem to get them right. Lots of firsts on this one for me, but great fun making it.
The candlestick is made of oak, just under 10inches high without candle, base is 4.5inches diameter, the stem is just under 2inches diameter, made in 3 parts, base, stem and cup/saucer. Most of the base and top shaped with a 3/4in skew, rounded the stem, then drilled a 10mm hole through the stem, marked out the spiral, and sawed, rasped, filed and sanded them. Sanded to 400 grit, 2 coats of Rustin Button Polish to seal, then 2 coats of Black Bison Fine Paste Wax.
DougieH
Ain't going to make this one, better luck next month.
Aidan
Curse you DIY.
with my apologies to Mark Sfirri, I thought I would jump in with both feet and try my first candlestick with my first attempt at multi axis turning. I used a piece of scrap pine for a practice run and then glued up three pieces of yew I had rescued from a pile of firewood on Vancouver Island. This round slippery slope thing is very contagious. Finished with three coats of Danish oil and then polished with the Oneway buffing wheel system. It is 12" high and 3" in diameter at the base and 1 3/8" in diameter at the top. Turned on 3 different axis.
    177.1 KB
    180 KB
    184.1 KB
Well for those who wondered what I was going to do with the piece of Russian Olive I posted earlier this month this is the adjacent piece. It was almost as misformed and fun to start! Roughed out with a 1" roughing gouge, detail with a 3/8th and 1/4" spindle gouge and the flutes cut with a 1/4" Forsner bit. Once again, the left hand thread was easier to do than the right.. Finished with Chestnut Hard Wax Oil and buffed with canaube wax. 9" high by 2 3/4" diameter base.
Hi All
This was made from 3 pieces of Oak.
Measures 355mm Tall, 145 mm at base and 130 mm at the top. Main column 75mm
Main pillar turned to 75 mm with tenon top and bottom to set into top and bottom. Rebated on tob and bottom to give clean join line.
Finished with finnishing oil
This competition gave me the ideal chance to learn how to use the sorby spiraling cutter I had for Christmas, Candle stick length is 11” base 6 ½” top 3 ¼” both made out of mahogany, stem 2 ¼” made out of beach base and top were treated with food safe oil stem with hard wax oil.
Tools used was the Robert Sorby 6mm spiraling cutter 1” roughing gouge and ¾“skew to round base top and stem 3/8” bowl gouge to shape top and bottom, 1 1/4 “ forsner bit for tenon top and bottom candle rebate “hole” drilled with a 1 3/4 forsner bit.
    167.1 KB
    207.5 KB
    200.7 KB
Hi,
!2 inches in height, Mahogany, finished with sanding sealer then carnuba. Obviously in two parts,
Here's mine.
Turned from a lump of something tropical, heavy and jolly hard with some form of silicate inclusion.
If anyone knows what wood it is then please pm me so as not to pollute this thread.
I had to sharpen the tools far too frequently.
It's about 10" tall and a little under 5" diameter at the base.
There are quite a lot of little cracks running through the wood, but hopefully it will survive :)
Finished with clear chestnut woodwax 22.
    225.3 KB
    236 KB
    247.7 KB
This is my entry for February. It is made from ash and it measures 23cm tall, 5.5cm wide at the base and 2cm wide at the stem. I have kept the design simple and to colour the top and bottom I have burned it.
I have finished it with cellulose sanding sealer.
Made from Laburnum 11" high, base is just under 3". While finishing the base part of it broke off so I removed the whole of the base and used what was to hand which was burr elm. Finished with friction polish.
    110.3 KB
    95.1 KB
    101.1 KB
My candlestick for Februarys comp,
13" High 6" at its widest, The stick is maple with a brass insert, drip tray in oak and base made of spalted sycamore, all finished with sanding sealer, cut back and soft paste wax buffed up.
Think I've been listening to war of the worlds too much in the workshop! this gave me the idea for the 3 legs, the base was originally a nice bowl but I went through the bottom of it and put it to one side for inspiration later, made up of 3 parts with the maple stick section acting as a tenon through the oak and sycamore to hold it all together, the sycamore bowl was marked up into 3 legs with dividers, cut on the bandsaw and shaped with a belt sander, I wanted to try something different as this is something I wouldn't usually make but had great fun doing so.
Regards Chris.
    70.5 KB
    66.7 KB
    71.9 KB
25cm tall, 8cm widest diameter, 4.5cm top diameter. Wood unknown.
Simple shape turned. 6 spirals drawn using indexing and equal spacings along the length. Then carved using Dremel powered carving head and Flexcut chisels.
Finally lots of sanding using a combination of sandpaper, 3M Radial bristles (not that impressed!), home made radial sanding pads in the Dremel.
Finished by buffing with tripoli compound on the buffing system. My thinking here was that any further finish could get damaged by wax dripping down the spiral grooves (and this wax running down the grooves is something I like the idea of).
[note - no metal insert as I didn't have one]
Duncan
Here we go, my first stick (couldnt find a candle the right size :oops: ) , and my first piece presented to the public, only had the lathe since Christmas. Went for simple but solid. It is 12 inches tall, 4in across the base. Unknown wood from the bottom of the firewood pile, finished to 400grt , liberon lathe polish and carnuba wax. photographed with cr*p camera!
hope i haven't embarrassed myself :)
    114.4 KB
    109.2 KB
    87.5 KB
Made from spalted sycamore, 9.5" tall, the width varies from just over 3" at the base down to about 0.75" at the narrowest part.
I got a good finish straight off the tool, so only needed a light sanding with 240 grit abrasive.
I then applied a coat of sanding sealer, and de-nibbed it with 400 grit abrasive.
Finally a coat of Black Bison paste wax buffed to a shine.
    164.4 KB
    159.6 KB
    171.3 KB
Mine is made from spalted beech. It's 25cm high and the base is 7cm across.
Roughed round between centres and spigot turned on the bottom. Then into the chuck and the hole for the candle drilled with a forstner and shaped a bit more with a box scraper. Top then shaped, sanded and waxed to finish. Wine-bottle cork stuck in the end where the candle goes and tailstock brought up to the cork. Wasn't sure about the cork but it worked fine!
Then to battle with various spindle gouges and skews which hardly ever get used and always turn the air blue. Cleaned up by shear scraping as much as I could get to then sanded through the grades trying not to to lose what little detail I had managed to achieve.
Finally 2 coats of sanding sealer followed by 2 coats of Chestnut Renaissance wax.
    208.5 KB
    217.4 KB
    248.4 KB
Made from three seprate pieces of Mahogany 5 1/2" dia at widest point 16" tall
finished in beeswax
Dave
Status
