Phil Pascoe
Which was my point.I suppose there's really no right or wrong in bench preference, i.e., flat or with tool well, and it's down to user preference. Slainte.
Oh heck Richard, I’ve always had a well, not so much for tools as all the other detritus, pencils, bits of card, sundry little bits of wood that come in handy, etc etc. And now I have a hankering for a freestanding split top bench, as aposed to my huge Beech wall mounted one, I just assumed it would be a joy to use, now I’m seriously reconsidering. I’ve always had a couple of large assembly tables which tbh I seem to spend more time at than my bench, so with a non well bench, is it that you are always clearing and cleaning? It’s making me think that only the tools and wood that’s next to be worked on will be on the top? Never tried a flat top so would you mind expanding on the pitfalls pls? IanYou can't, because it isn't.
Actually, I don't 'need' one, I just much prefer to have one, given a choice. My personal workbench has one, and I wouldn't choose to have it any other way, but I've worked on plenty of benches in workshops that were simply flat surfaces and I've disliked every one.
Similar to yourself, I find the well is a handy place to store a mixture of tools and oddments: chisels, spokeshaves, hammers, marking knives, saws, etc, plus bits of hardware, abrasive papers, shavings, etc, even somewhere to put routers, drills (cordless or otherwise), and so on. All that stuff gets sorted at the end of the day in my case, if the well hasn't already had a bit of a clear out at other points to create a flat space on which to lay a frame, panel, or whatever to work on.Oh heck Richard, I’ve always had a well, not so much for tools as all the other detritus, pencils, bits of card, sundry little bits of wood that come in handy, etc etc. And now I have a hankering for a freestanding split top bench, as aposed to my huge Beech wall mounted one, I just assumed it would be a joy to use, now I’m seriously reconsidering. I’ve always had a couple of large assembly tables which tbh I seem to spend more time at than my bench, so with a non well bench, is it that you are always clearing and cleaning? It’s making me think that only the tools and wood that’s next to be worked on will be on the top? Never tried a flat top so would you mind expanding on the pitfalls pls? Ian
Thanks for that Richard, definitely given me something to think about. IanSimilar to yourself, I find the well is a handy place to store a mixture of tools and oddments: chisels, spokeshaves, hammers, marking knives, saws, etc, plus bits of hardware, abrasive papers, shavings, etc, even somewhere to put routers, drills (cordless or otherwise), and so on. All that stuff gets sorted at the end of the day in my case, if the well hasn't already had a bit of a clear out at other points to create a flat space on which to lay a frame, panel, or whatever to work on.
I suppose, for me, the key is that even something that sticks up from the tool well, like a router, for instance is hard to accidentally knock out of the well and onto the floor. Other stuff, such as chisels, hammers, saws, etc, that sit in the well and below the level of the main bench top can't get swept off to the floor.
On the other hand, in places where the bench tops were flat, I've seen quite a number of tools accidentally knocked off as someone slides a piece of work around on the bench to get it into a more convenient position on which to work. I don't think I've ever broken anything expensive of my own that's been knocked on the floor, and perhaps the worst was a chisel that hit concrete and had to be reground and sharpened. But I have seen other woodworking tools get damaged, sometimes beyond repair, e.g., routers, buzz saws, cordless drills, hand planes, etc that didn't survive the journey from the bench top to the concrete floor.
I like a tool well for all the reasons above, but it's also very useful to have a flat assembly area nearby dedicated for glue ups, cabinet assembly, and so on. Given enough space I'd definitely have my workbench with its tool well, plus a couple of large 2440 X 1220 mm assembly type tables, basically a bit of ply or MDF, perhaps reinforced with some bearers on trestles would do. I don't have the luxury of so much space so my little work area can only house the workbench, with its well, ha, ha. Slainte.
I think you're worrying about nothing regarding the top needing to be firmly attached via through mortises.
If you look at most Scandi benches, there is no upper stretcher either and the top just sits onto the trestles with some bullet shaped dowels for alignment.
Not that I'd do that either with your design, as most Scandi benches do have a wide strecher to counter racking,
but just saying you could get away without needing big tenons through your bench top, I don't think tenon depth is as critical here, as would be with the rails and strechers.
You might like the contrast though, and that's you're call.
If you changed you're mind and still concerned, then you could add some anti racking features to the center strip/ planing stop.
I am getting closer to the day I will start working on the new workbench. What I was now considering is the order in which I will work the various pieces of the workbench and, as usual, I would like to have some feedback from the community!
This is the order I was thinking:
is the order correct? do you think I am missing any step? anything I should look out for?
- cut the stock to the right size. ripping with the track saw and cutting to length with the mitre saw
- laminate the legs
- cut the legs tenons
- cut the stretchers tenons
- cut the legs through mortices using the stretchers' tenons
- dry fit the frame and check everything is square
- fit for good with glue the through tenons for the short stretchers, and leave the tusk tenons glue-free
- laminate the two parts of the top
- roughly plane the bottom part of the top flush (I assume I will try my hardest to keep the top part of the tops flush when laminating)
- cut the tops' blind mortices using the legs' tenons as a reference
- drill the dowel holes in the top stretchers, then dry fit everything and mark the bottom part of the top for the dowel holes
- actually fit everything for good (no glue to fit the top)
- plane the top part of the tops and the central planing strip/beam flush
- make the dog holes with the plunge router and a gig; I will need to check what gig to use, as I have abandoned my idea doing it on the pillar drill with auger bits since I will do it last
- start doing some real work on that workbench!
Thanks everyone
