patl
Hi everyone,
Having lurked for a little while now, I've appreciated all the advice I've found so far, but I'm still in a bit of a quandary.
First, I guess a little background may be in order. As seems to be fairly typical around here, I did a fair amount of woodworking before I left home, but after the better part of 20 years living in small flats, I've finally moved into a house with enough space for a workshop, so I'm re-introducing myself to woodwork when more brutal DIY doesn't get in the way.
After picking up Axminster's cheap groz bench & block plane set, I'm still finding planing to be about as painful as exerience as it was when I was younger, even with razor sharp blades (I hope there's only a small element of a bad workman blaming his tools here...). So I'm hoping if I move up the scale a little it may become a slightly more pleasurable experience, with that in mind, and all the good advice that's come from the archives, I've got a reconditioned no 5 1/2 coming from ray Iles and I plan on a veritas apron plane as a general purpose block plane.
However, I'm now wondering what to do on the shoulder plane (or some kind of plane for planing up to an edge) front. Since my budget at this stage is around 50-60 for each plane, I'm thinking about a new stanley no 062 but are there any other/better options without breaking the bank, or should I just accept that I'm going to have to spend more serious money on this plane?
Although I take the inevitable and good point that getting an old one and fettling it is a better/cheaper way to go. My problem is that without a well setup one to use as a reference, my best efforts at fettling (bar blade sharpening) are likely to be at best pointless. So I'm really looking for something which I only need to sharpen the blade to get to a reasonable tool.
Anyway, thanks for helping to grease the slide...
Pat.
Pat.
