Xcalibur - pics
just came across this Steve,
bit late and looking forward to your pics.
I have the unisaw but by all accounts the xcaliber is a close clone. Ideal for the home user.
You'll best need a bit of 2.5mm 3 core cable with a 16amp blue plug and socket. then connected to a 32amp supply preferably with an elcb 100ma trip, 30ma is a bit too fine, particularly if your shop is slightly damp
I've just discovered i am not allowed to wire my own electrics in the house although i am allowed to inspect ex equipement. meggar generators i work on 33000 and 11000 volts and 440v but i'm not registered with the council for domestic. great excuse for not doing homers.
I
Ian
I could well be wrong here as I have lent my regs book out to someone, but don't all sockets feeds have to be covered by 30mA protection in an outbuilding/garage at least in this instance of a new install? If the installation could be classed as part of the house itself it may be possible to get round it. I am however not a qualified elctrician.
Cheers Alan
Hi all, pics as promised.
It arrived on a pallet, covered in plywood, with the rails poking out of the top and the fence in a separate cardboard box. All we'll packaged and no damage. When I took off the plywood, this is what I saw:
It's a beast of a motor, and the whole thing weighs a tonne (well, quarter of a tonne, actually), but somehow I managed to get it inside before the sun went down.
The first priority was to get it on wheels. This is an ordinary Aminster one, and it works better than I expected it to, actually. I've abandoned my idea of earlier in the thread, because the dust port is on the right side, not the back as I had assumed, and that would interfere with the mechanism. Pity really, I think that was a goer, otherwise.
This morning my friend came round and helped my put on the table extensions etc. The motor cover is the last to go on, otherwise you can't get your spanner in there.
The rails stretch from here to Derby. I've put them on temporarily, and I can't bring myself to cut them (especially as this is on loan), so I'm off to a steel stockholder on the other side of town tomorrow.
It's against the wall at the mo, just because the rails are so long, but I'll turn it through 90 degrees in use.
Installation was straightforward. Thanks to Alan for warning me about the large amounts of goo. I scraped loads off and still used a ton of WD 40. Smashing surfaces though.
It comes without a cable, but the connection box is easy to get at and the connections inside are substantial.
The blade was in line with the mitre slots, needing no adjustment. The tilt needed a quarter turn on the stop. The fence needed adjustment by a hair vertically and by 0.4mm over its length. All very easy to do. The fence works beautifully, smooth and rock solid. Nice switch. I'd prefer a finer line on the cursor, but the scale itself is clear and in metric and imperial.
Most of the manual is written in a language similar to English, but as there isn't actually much installation to do, it's pretty straightforward. Just don't go searching for the pan-head screws - they are countersunk. The guard is a later model than the manual shows.
Now I know I've been lent this for filming, so I'm not going to say anything which would upset Roy, am I? Actually he was helpful and supportive from the first, and he didn't know who I was then. (It's a good way to be brought down to earth, when one gets tempted to think that I, Steve Maskery, Internationally Renowned Woodworking Superstar, am needed by my Public, by someone who says, "I don't know you from Adam".) So you have to take all this with that caveat in mind. But I can tell you that if I say something is good, it means I think it is good. I'm not going to compromise my personal integrity for anyone else. If I don't like something, I just won't mention it. That's true for anything I say about Festool or JSP, too, for that matter.
In the words of the song, "If you can't say anything real nice, not to talk at all is my advice".
As it happens, as far as I can tell from just installing it, there is very much to like and very little indeed to quibble with. We'll see when we actually come to using it in anger. Yes the cursor could be finer, and the pointer on the mitre fence is a bit far from the scale. But that's about it. I was pleased to discover my best Freud thin-kerf blade works with the riving knife, I thought I was going to have to make a replacement.
It's a solid, confidence-inspiring piece of no-frills engineering. There are THREE belts driving a very substantial arbour. It is a build-quality much higher that I think Taiwanese to be, they have really got their act together. There is nothing which feels flimsy. The extension tables fit nice and flush all the way along. Rise and fall is nice and smooth. All loverly, loverly, loverly.
The only problem is the size really, and once I have that sorted, it should be just the ticket, especially as the machine itself is not very much bigger than the one it replaced. Just much, much more substantial. I'm really looking forward to using it.
Finally, does anyone know how I can host my pics with (in this case) Fotopic but have them displayed here directly instead of as a link? I've always used my own webspace before, but if I can store them elsewhere I'd rather do so. But I can only find how to link to the HTML page, not the photo itself. Have I just picked the wrong provider? Edit - Sorted, thanks.
http://www.fotopic.net/help/directlinking.php
Does that help ?
Hi all,
Mine arrived today on a big truck with tail lift and a very helpful driver who had a high clearance pallet lifter with fat rubber wheels, just ran the crate straight into my WS.
Waka came over and we got the beast onto its custom trolley in 5 mins flat and fitted the wings no problems.
Will sort the rest tomorrow after a woodkateer outing to Yandles :twisted:
So far very impressed with the build quality and finish.
Regards,
Martin
Looking good Steve :) I don't think you'll be disappointed with the 806 - it's a lovely bit of kit 8)
It's good to know that the Axminster wheel base works okay with it. I've been thinking of making my saw mobile...
Thanks Wizer, just what I need. I think I'm going to have to shrink my pics a bit and reload them though. I'll perhaps do that later. I've had to take my eyes out and Judith will be here soon wanting to know where her dinner is!
no, no, no ,no - i can't :cry: :cry:
Thanks for that Steve. What table saw did it replace please?
Can't what, Lynx? Are we green by any chance? :)
I had a 15-year old Axminster. Cast iron top. It is pretty crude really. I had the motor rewound years ago, the guard went years ago, the pulley guard lasted a week, the fence was useless and I made my own from plans in FWW. It has a simple switch, not an NVR.
Despite all that it was a good saw! It took everything I threw at it for all these years, cut accurately, and, once I'd built my own fence, pulley guard etc, it did me proud. It has a long nose spindle, too. :) And it wasn't as if it was expensive in the first place.
However, it still had no gaurd, except those I build into my jigs, and there is no brake on it. It takes 9.9 seconds to stop. So I couldn't really film it as any kind of recommendation, and it's why you never see it in any photos in GW.
It's gone to a mate who is ill, but spends what time he can in his garage making furniture. He gets loads of work, mainly becasue he works for less than minimum wage!
Sheesh, and then he gets this saw off a "mate" to add to his woes. Really Steve... :roll: :lol:
Not green but i was set on the 10" SIP, the xcaliber had been crossed off. Looks like the rubbers coming out and it's back on the list.
It's just those bloody rails, too long and i will have to cut them.
Steve,
Have you left the belt tension as supplied or tightened them up?
The manual says 1/4" with the weight of the motor on the belts but Roy says they are factory set. My tension is a good 1/2"+ of easy movement.
My blades and arbour extension are coming separately apparently. :roll:
Will be sorting out the fence, rails and outfeed stuff today and getting the kit for the electrics too, can't wait! :p :p
Regards,
martin
Martin
I've not touched the belts - actually it never occurred to me to check them.
If you go out to buy stuff for the electrics, remember to get some of those round crimped terminators - no idea what they are called. I went out to buy the cable, then had to go out again as I'd not taken the cover off to see what I was dealing with. There are three posts inside the connecting box, and the cable is much easier to fit if it has these round thingies on, rather than trying to wrap the core around the posts.
I keep nipping into the workshop and switching it on, just to hear it purr. And I keep giggling, it's driving Judith nuts.
Just been out this morning to buy some steel for a shorter fence. Very helpful place, £20 cut to length for me.
