David C":3scijsmj said:
I originally suggested / requested the honing guide modification to Thomas back in about 2001 when we were shooting the plane sharpening video.
The idea was to have plane blade holding jaws similar to the chisel holding jaws. This would mean that the honing angle would be the same for differing blade thicknesses at a particular projection.
David Charlesworth
Well...
it is clearly a mathematical fact that different blade thickness will result in different angles for a given projection, in an Eclipse style jig.
However, a thread a while ago actually tabulated the permutations, intended (I think) to allow accurate setting of bevel angles.
However, reading the table, I came to an almost opposite conclusion.
Given that the required projections for typical angles are large compared to the thickness variation in the blades, the table says that while the bevel angle for a given projection does indeed vary with blade thickness, it
doesn't vary by much.
Further, minor variations in bevel angle are not a big deal; even when using a bevel up plane, where the EP controls tearout, I've not heard anyone claim that angle changes of 1-2 degrees are significant; angular changes are normally quoted in multiples of 5.
Consistency between sharpenings is (IMHO) super important, since it has a direct influence on the amount of honing work to be done, and amount of precious tool steel ground away. A constant projection gives this, even if the angle is more nominal than accurate.
(thread referenced:
https://www.ukworkshop.co.uk/forums/view ... ess#309130
There is sometimes another reason for wanting to clamp the "back face" though; I've had some mortise chisels where the front face was cambered, and even the apex wasn't symmetrical w.r.t. the back. Clamping w.r.t. the back was the only way to clamp at all.
BugBear
