I am considering enlarging my workshop if my wife will grant me planning permission! At the moment my electricity comes via a 2.5mm spur taken off a house ring main using armoured cable so the power is limited, although I haven't had a problem to date. Before doing any building work I want to improve my electrics. In my garage I have an unused 10mm cable with its own connection to the consumer unit and I would like to run that to my workshop but I think that as I have managed so far with a more limited supply then a 6mm cable will be more than I need.
My thoughts are that I would like to link the 10mm twin and earth cable to 6mm pvc cable using a junction box in the garage ceiling cavity and then joining the 6mm pvc cable to 6mm armoured cable, using a junction box mounted on the outside of the garage wall. I would then bury the armoured cable underground and run it to my workshop where I would connect it to a small consumer unit . The 2.5 mm armoured cable can then be disconnected and left underground.
Does that sound like a reasonable plan? Thanks for any advice.
