Workshop wall structure
vmvseoa
19 May 2011
Sunny Manchester
Hi all, I am new to this forum and have read loads of really interesting threads. I am hoping to build my own workshop at some point in the future, and was hoping for some advice on the correct structure of a timber wall :? From what I can gather it should be, from outside in, cladding - air gap - breather membrane - studding (incorporating insulation) - waterproof membrane - internal cladding. Can someone advise if I have this right please?
vmvseoa
If you are talking about building a timber wall that would pass building regs requirements for the purposes of accommodation . The answer is yes. If you are talking about a wall as in a shed though not wrong may well be more than required.
all the best
rob
vmvseoa
On the inside - it would be a vapour barrier.
Not being picky but if you walked into a Builder's merchants and asked for a waterproof barrier you might get some weird looks or some other product like a tarp! :mrgreen:
The construction - I would have a sheet of something, either ply or OSB behind the breather membrane and in front of the studs. Possibly on the inside of the studs as well
Welcome aboard. Shed constuction threads are some of the most popular, so make sure you record your progress on here - you'll get plenty of help.
And in case your reading of old posts hasn't yet got to it, you really ought to have a look at this thread from an architect who sadly doesn't post on here any more, but left us some good stuff:
https://www.ukworkshop.co.uk/forums/build-a-shed-mike-s-way-t39389.html
welcome to the forum
Here is my WIP - and I recently asked a similar question to you!
workshop-design-t48664-45.html
Anyone else thinking of plasterboard for the inner cladding? A quarter the price of ply ...
A quarter of the strength though. A kick back on the TS or even you slipping while carrying some planks would make a nice hole, If you want to save money I would use thiner ply. However if you use a descent thinknes of ply you need not worry to much about finding a stud or noggin when hanging heavy things.
OP Welcome, any family guy fan automatically gets my vote.
Sorry about the delay in replying, been in hospital, thanks for all the replies. Plasterboard, Interesting, I never thought of that. I currently have a prefab concrete garage of 6x2.5m, which is structurally sound, and only leaks from the roof. My initial thoughts were to take down 4m of paneling from one side of this and building it out in timber another 2.5m to the side, then by rebuilding the side approx 4.5m, to create a (roughly) 5x4.5m square with a 2x2.5m room at the back, (basically to create an L shape building) then cover it all with a flat roof and clad it all to make it look all of the same construction.
I was going to move the workshop into the newly created building, but as woodworking is a hobby, not my job, and most of the stuff I make is for family or friends, I'm now thinking more towards keeping the shed, but moving all the tools, stains, wood etc into the small room that would be created at the back of the garage. This would free up loads of space in the shed for construction, and would also offer more security for my tools. The largest piece of furniture I have made so far is a double wardrobe. This was a struggle in the shed, but any furniture I make, I tend build into finished, manageable panels where possible, then do the final assembly in situ as I it's easier to move about. I could then turn the 5x4.5m bit of the garage into a pool room/gym.
My next questions therefore are:-
1. has anyone ever extended a concrete sectional garage with timber, or heard of anyone doing it, or is this a stupid idea?
2. the max 30m2 you can build under permitted development, is that the internal, or external measurements of the building?
vmvseoa
vmvseoa
1. never heard of it.
2. External if someone from the Council comes to measure it and internal if no-one complains. :wink:
Dibs
