gidon
Prompted by another post I thought I'd show my workshop and how I have come to use the space available.
If you click on the picture below it'll take you to a interactive panorama of my workshop (spot the joins!).
The workshop is a 14' by 8' shed at the back of the garden. Needs a lot of work doing to it but it came with the house so can't really complain. The wood is out of shot but is mainly stacked on beams attached across the roof. I should really wear a hard hat in there!
All machines are on wheels but I 've organised it so that the p/t'er and table saw can be used for general tasks without moving anything out of the way. So can the bandsaw for very small tasks. Moving the table saw to one side, and opening the door I can (and have just recently) planed and thicknessed 6' lengths quite easily.
So that side of the workshop I'm happy with. The other side is more cramped but works ok for most things. I've built full extension drawers underneath the router table and bench which are incredibly useful. The bench is really in the wrong place - since I can't really use one end of it! But hard to know exactly where to put it. It's not the best anyway - it's not really deep enough.
I use the router table, bench and table saw (with blade retracted) as worktops. And bring the drill press and morticer onto the router table usually. I need to sort something out with the morticer (recent purchase) really - it's flippin' heavy to lift off the floor!
Also out of shot is a Microclene air filter which is good but I find too noisy to have on all the time. I also have an drum extractor (in shot next to the table saw) which is used for the table saw and p/t. And I have a smaller workshop vac for the router table, power tools and general tidy up.
The lighting is awful - although at least there is some natural light. This is another thing I need to sort out. The trouble is because the wood is stored overhead - it blocks the small amount of lighting there is - doh!
The dehumidifier is on a humidtsat and has helped considerably. I also have an electric heater which is on frost guard mode and works well alongside the dehumidifier (they don't work well below 5C). This also needs to be replaced - bit of a fire risk.
If you notice the table saw (above the sheet timber at the back) and p/t attachments (next to the front door) have their own storage allocated. That is crucial - I would bever be able to find space for the sliding table extension or planer table otherwise.
What would I change if I could? I find the length ok - but could do with 2' (++) more width. I would have a flat floor for sliding the machines around! I would add better lighting. And if I had loads more space I would just love to have a proper sized bench with space all around it!
Well there you go - that was fun wasn't it? Wakey wakey!!
Gidon
Gidon
