Yo, So continuing on from this thread in the General section, now that work has started I am posting here instead.
workshop-roof-t46774.html
To date: I had a load of wood that I got half-price, so had to work around what I had, which has thrown a few problems. I also changed a few design details as I went along, which is probably why I am having the grief I am now having.... haha, oh well I have learnt that you should start with a complete plan of action before cutting anything..... Anyway I am at the following stage : Four walls built, but now having problems with the roof. :evil:
I was planning on having a flat roof (as discussed on previous thread) but as OLD pointed out previously, I would need to buy some 6x2s to safely span - so instead I am chaning to an Apex design in the hope that I can get this built without having to buy any additional timber. I have 20 lengths of 3.6m 4x2 remaining, and a quarter have some bad warps, so its gonna be tight.
Here is a sketch-up of my latest roof plan. The trusses will be spaced approx 450mm and have 12mm Plywood gussets (which I have not drawn in Sketch-up). I was unsure if they need an upright in the middle (what is that called, a king-post or something?)
Anyway - two questions.
One: Will this design be robust enough to span the walls , which are 2.8m apart ?
Two: If it IS strong enough, could I push the new design one step further and raise the chord (second pic) or would that weaken it ?
Bottom chord sits on wall plates:
Raised bottom chord:
