Apologies in advance for the long post. My garage, that I use as a workshop, is approx 22 foot square. Its a nice space although I have to maintain the illusion that one day we will be able to park cars inside it.
The problem is that it has a galvanised steel corrugated roof and, in Winter, condensation problems result in it 'raining' on the inside. I have put up with this already for several years but now that I have become more serious about woodworking and have invested in some stationary tools, it is a real pain.
Basically from about this time through to Spring, the combination of a constantly dripping roof and the cold means that every bit of equipment has to be covered and I cannot do any more work.
Have any of you had a similar experience and how did you solve it?
I am told that the answer is to insulate the roof space. The roof is supported by frames (about 9" high) made of steel angle, welded together from mountings buit into the garage walls (brick). The outside roof profile is a typical shallow V shape. The bottom of the roof supporting frame is parallel to the roof at the edges and flat for approx 4ft under the ridge.
I had intended to use 3 x 2 cls studwork timber bolted through the 3" wide edge up into the bottom of the steel frames (supports) at 2 foot centres. Then use cross pieces on 4 ft centres (staggered) and buy waterproof(?) green chipboard flooring panels from Wickes (8ft x 2ft) to form a suspended roof / ceiling. Above this I guess I would need some form of insulation material but, again, I'm not sure what type to buy.
Does this appear to be a reasonable way forward or am I missing something?
The other concern I have is that, occasionally, we get a mouse in the garage. Would I be building a huge nesting site?
Your views would be very welcome. Thanks.
