LED Lights. From a Lighting Engineer - Part 2
Not all LED Lights are the same. There are cheap fittings and expensive ones and you do get what you pay for. That said; i design lighting for education, hospitals and offices etc. So please be aware that my dim view of cheaper fittings will be coloured by this. My customers demand long fitting life and many hours use. You will have to work with your budget and hours of use.
Heat affects the life of LEDs. Workshops will often be cool. So this will help increase fitting life.Add to this you won't be working 15+ hours a day.
Okay, so now some info on LED lighting.
Most LED lighting bought from an electrical wholesaler, Online LED resseller or retail outlet will be fittings sourced from a factory selling fittings to the market for less than £5 each. They will often have a 5 year warranty, but you should read the terms thoroughly. Many wil be "guaranteed against 100% failure" So if any of the Less are still working, no matter how dim, you won't be able to claim.
The OP
@MacGyver talked about feeling motion sickness. This will probably be due to strange instability in the LED driver, or the LED boards. The power supply may not be putting out a good clean output, causing a bad reaction in the board.
Someone here mentioned Philips Lighting. Philips make good lamps and Panels. So do buy them with confidence. (I don't work for Philips).
Other good suppliers are: Tridonic, Whitecroft, Apollo Lighting and Thorlux.
LED Panels.
There are good panels and bad. Good ones will be priced at around £50+.
All LED panels have the LEDs located, facing sideways around the edge. This doesn't give a lot if space for the LEDs to sit. There also isn't going to be much metal there for providing a heatsink to dissipate heat from the LED components. This heat will shorten the life.
Add to this the fact that the maker will want to get as much light as they can from the limited number of LEDs. So they will crank up the circuit current to make the LEDs work harder; shorter life. So if you're offered 600x600 panels with over 3500 lumen output, be aware the life may not be impressive. Yet, again, if you only use the workshop a few hours a week, then this may not be an issue.
LED Replacement tubes.
These are not something I would ever recommend. These generally require the mains voltage of 230v to be connected directly to the fluorescent lamp terminals. These lamp holders are designed to a voltage of nearer 20v after the starting surge voltage. So by installing these you're making an electrical decision I would consider brave.
I hope this is helpful to you. Please feel free to ask questions. If I have upset anyone who has just bought lighting, then I apologise, but I can only talk honestly.
