9fingers
I've been working on building my new workshop for the last year and am drawing to a close on the shell.
I had thought about installing a Hotspot or similar woodburning stove but recent experience is suggesting otherwise.
The workshop is 10 feet x 30 feet and just tall enough to swing an 8x4 sheet corner to corner.
I have 25mm polystyrene insulation under the floor and in the walls and 100mm of fibreglass in the roof. It is also completely draught tight.
Last night we had a frost and inside I left a 750 watt oil filled radiator with the thermostat set fairly high. This morning it was 12 degrees C in there and I was reasonably comfortable after a few minutes of light physical work.
I conclude from this that
a) Insulation and draught proofing is well worthwhile
b) A woodburner is likely to emit far too much heat for a 2700 cu ft workshop.
BTW - sorry I've not taken many pictures during the build. Maybe once I start fitting out the interior I'll be more active with the camera.
To summarize the construction
Construction is single skin 100mm high density concrete blocks clad on the outside with 8" feather board. Pitched roof with fibre cement slates. The interior is clad with 18mm ply on the walls, 18mm hardwood ply on the floor and the ceiling is 6mm mdf. Walls and ceiling will be emulsioned white. Ply walls will mean I can screw cupboards, benches shelves etc anywhere I want to.
There are deliberately no windows for the same reason. An extractor fan will allow cooling in the summer if the insulation allows too much heat in.
Bob
Bob
