Yojevol
Clocking on
This sander is in very good condition. It is the same as the current offering from Axminster apart from the provision of a table lifting screw jack. I use a simple hydraulic bottle jack which makes it an easy operation. I can include the jack if the buyer doesn't already own one.
The unit can be used in 3 modes:-
1. Vertical as in photo
2. with the belt laid flat. There is a fence than can be deployed in this mode
3. as a contour sander for which an end table is provided - see photo.
It comes with a good supply of belts - 1 x P80, 4 x P100, 1 x P120 (lightly used), 1 x P180 (almost new) as well as the P120 in use.
The castored base is also included if required
Be aware that this is a 16A machine running on 230V
£500 collected from GL19
