NetBlindPaul":2u5pukxb said:The fire risk is often seen when screwed connections are not correctly made, often by DIYers.
NetBlindPaul":2u5pukxb said:The potentially lethal fault can come from several failure modes, to do a full FMEA I would need the full details of the install, the upstream cct protection and the characteristics of the supply at the origin.
NetBlindPaul":2u5pukxb said:Please also remember that when an electrician comes to work at your home, this becomes his pace of work he thus has to comply with all work place legislation.
If he is to fit this for the constructor he has to also comply with CDM & work at height legislation, thus the joint must be in a position where by it can be inspected without the necessity of working at height as it is possible that live working could be needed at that location.
Thus remove the joint and you remove the requirement for access for inspection & testing at height.
Paul
Deejay":3lss1hh9 said:Morning KC
Mike - I am trying to stick to wood so I hope 200 x 500 x c.7000 for my ridge.
Sounds a bit big. Are you sure?
200 x 50 sounds better to me.![]()
Dave
NetBlindPaul":1ht5ibph said:The building regulations require absolute compliance and they can be applied such that any non compliant works must be re-done in compliance, this remember includes the requirement to insulate structures, include natural lighting etc. no matter what the intended purpose / “person” constructing. LABC have within their powers to have the construction “removed”!
NetBlindPaul":2iqt66gc said:Dibs, I have seen the reality also, however that is the statute law, one should not advocate breaking the law should one!
kingcod":2iqt66gc said:So I have my concrete base in place now (pics to follow) and need to order up my concrete blocks. I am getting conflicting advice.
My design has a couple of rows of 440x215x100 standard blocks topped with a timber frame and timber roof. I am hoping to use the lightest blocks possible as I have to barrow them such a distance to the site. A builders yard is saying I need 7n dense blocks but surely I can get away with aerated blocks of the 3.6n variety? the blocks are above ground and are load bearing.
- oh and would hollow blocks do? I am thinking of using these to inset anchor bolts in for the sole plates. A bit like yer man here is doing:
kingcod":2iv15v8r said:The 7N blocks are all set to go. An hours work with a barrow to get on site . I am now puzzling over the position of the DPC and the sole plate. If I am resting the sole plate directly over the DPC can I still fix anchor bolts / paslode shots through the DPC into the concrete blocks? Surely thats another compromise on the DPC layer? I can't seem to find a simple alternative. I am looking at straps to fix the sole plate but not sure where to fix them at the base. If only I had followed the full Mike Garnham technique and concreted straps into the base. *sigh*
Would a DPC between the first and second course of concrete blocks do any good? Or would that make mortaring up the blocks a bit difficult?
johnf":2sehpmfc said:So what stops the damp rising into the bottom course of blockwork
PS I am a bricklayer of 45 years experiance
Dibs-h":1h0odbv3 said:johnf":1h0odbv3 said:So what stops the damp rising into the bottom course of blockwork
If there hadn't been a DPM under the concrete I would have thought nothing, but looking at the earlier pictures - there's a DPM under the concrete, in which case a DPC appears pointless.
Dibs
kingcod":3q2p54nv said:Dibs-h":3q2p54nv said:johnf":3q2p54nv said:So what stops the damp rising into the bottom course of blockwork
Dibs
Yes there is a1200 guage DPM under the concrete. As for the DPC ... I was just following Mike Garnham's design which shows both:
build-a-shed-mike-s-way-t39389.html
Which brings me to a few questions:
1. Double sole plate or single sole plate? I have seen designs with both.
2. How to treat the DPC at the doorway. If you can imagine it appears out the wall at i block height ... should I extend it down and around the base of the door frame and door step (which will all be in wood)?
3. Any special treatment needed for the wood fram, particularly the sole plate as the most potentially exposed section? Do I need tanalised timber or will Kiln Dried C16 do?
4. screws with an impact driver or ringnails with an air nailer to stick build the frame?
5. Should I fastidiously protect the half built frame from the weather or just work on and let it dry through once it gets clad?
Thats it. Advice greatly appreciated
