stage1v8
Hi Folks,
Kinda new to this wood working lark. Usually could be seen creating sparks with bits of metal in the past! Enjoying reading the posts on here and learning loads every time I log in.
So here is my first project!
I have been given a few tools by my father to add to my collection so started to think about converting the cellar into a workshop. Its not very big (8'x12') and the roofs a bit low (I am 6'3" and the roof is 6'2" to the plaster board a previous owner lined it with) but I am hoping with a bit of clever design I can make it usable.
Here is a picture of the layout:
On the right there are 2 x 14" square brick pillars supporting the fireplace and chimney in the room above and a 3" stone slab at waist height in the corner.
Here is what I want to fit in:
General tools and tool boxes - Thinking shelves, drawers & cupboards
Workbench - Thinking fold down/up workbench in front of brick pillars that extends in to the space between the pillars so when in place is 14" wider.
Mitre saw - may just leave that portable and sink some threaded fixings into the work bench to mount it with some extension fence things that clamp on either side.
Table saw - Currently have a cheap 10" saw that I intend to make a mobile stand for with fold up side extensions and out feed. Could also use fold up work bench if heights all made to line up.
The main think I am looking for peoples suggestions on is the work bench. I have 2 ideas:
1. Fold up/down.
Pro's:
Gives me more space when folded away
Cons:
May not be as sturdy as a fixed one.
Loose possible cupboard and drawer space created under a fixed workbench
2. Fixed/built in
Pro's:
Could be made full width and incorporate the stone slab area giving a 10' long work top 600-800 mm deep but with 2 x 14' brick pillars sticking into it.
Can build drawers and cupboards underneath to give a lot of storage
Could build a recess for the mitre saw that could be covered with a board when not being used.
Con's
Space!
What do people think?
I hope to build a router table into all of this as well but thats one for later in the year.
Jon
1. Fold up/down.
Pro's:
Cons:
2. Fixed/built in
Pro's:
Con's
Space!
Jon
