Having completed the groundworks for my workshop build I am now looking at some of the finer details of the construction which is based around the design of mailee who kindly sent me plans of his build.
I have a couple of questions
1. The floor will be timber with kingspan ployurethane insulation boards (from the seconds company recommended elsewhere) I was originally planning to lay these flush underneath the floor surface but the other day I was watching challenge tommy walsh (I know someone has to! ) and they were doing the one with the well in the middle of the floor. They insulated the floor using the same material but they said on the programme that they needed to leave an airgap between the insulation and the floorboards. Is that necessary?
2. I think I've understood the wall construction of inner lining, vapour barrier (plastic sheet), insulation, breathable membrane and outer cladding.
Would this http://www.screwfix.com/search.do;j...KCSTHZOSFFY?_dyncharset=UTF-8&fh_search=98160 be suitable for the breathable membrane layer? And should you leave a gap between this and the cladding, I'm planning to use shiplap boards?
Gav
Gav
