wcndave
Even with the mortise and tenon you can still separate the top. The mortises help hold it very square, with no racking, however I screwed the rails to the top with carriage bolts so I can take it off. I also made the end cap with doevtails, again not glued. The idea is I can remove the end cap, take the top off, and pass the two pieces through a planer / thicknesser if I ever need to. Granted you'd need big machines, but I know some wooden house building companies here that have them. To be fair, I actually flattened the top by hand anyway at the end, as it was less trouble, however I have the option. The mortises in the legs do add a lot, even unglued in terms of preventing any racking.
Frugal, do you know why Richard no longer sells the bar? You may struggle to make one as good, as the shaft is extremely smooth with about 200 ball bearings, and has very tight tolerances indeed.
Even so I found it a struggle to get it to run smoothly like in Richard's video. I can get it smooth, however then tightening the garter on the wooden screw makes the action rather stiff. The vice does the job perfectly, just quite stiff to wind it.
If he stopped making because it was too difficult to get working, you may want to rethink. However I do enjoy not having to move a pin around.
Have you seen Mark Spagnolo's Roubo build? very detailed videos, a good 4-5 hours in total I'd say.
