thetyreman
I planed the two to the same width now, exhausted lol it took a while but it will be worth it
MrTeroo":355v0dy8 said:I ended up with a twist in one of my leg frames.
I thought it would have to be done again but I went on Paul Sellers' 2 day introduction to woodworking course a couple of weeks ago and I asked him what I should do about that.
He told me not to worry because the locking wedges that secure the leg frames would correct the twist.
When I glued mine up and put the wedges in it was fine.
Richard Maguire's english bench video covered that exact point; he recommended shimming under the legs to straighten the frame before putting the top on because the top would hold the frame in whatever state it was in, twisted or not. Once you have the frame straight and the bench assembled, you can either shim under the leg to compensate for the floor or cut the legs to length (though that seems a bit extreme to me).I'm not sure what to do yet with this, I thought I'd ask here first, what do you think?
MrTeroo":mvsk9e7p said:It's not too late to incorporate wedges?
thetyreman":2a4x474b said:mmmh I'm going to try the legs on a flat surface and hopefully I'll see what is wrong, got to get this part of it right after all this work.
MrTeroo":38l54jcm said:These are the wedges I was referring to:
MrTeroo":1wjwb3fg said:Well according to Paul Sellers the wedge will just drop and tighten as the bench movement occurs.
thetyreman":22vwr0mb said:another note, that bench that MrTeroo is refering to is a different design by sellers, in the youtube video series, mr sellers says it was designed to be taken apart and put back together again, because he planned to use it for shows and travelling, so that may explain it custard.
The design I am using is from his book and DVD, and it IS slightly different, no leg wedges and a thinner wellboard, designed to be permanent.
MrTeroo":2mte23jj said:thetyreman":2mte23jj said:another note, that bench that MrTeroo is refering to is a different design by sellers, in the youtube video series, mr sellers says it was designed to be taken apart and put back together again, because he planned to use it for shows and travelling, so that may explain it custard.
Sorry :? Didn't know that.
