Bristol_Rob
See if you can find one of these made by Moore & Wright, sets up for square a treat, takes a bit of lifting mind:
Holy Moly...
Reminded me of speaking to someone who cleared out the workshops of a defunct mining machinery manufacturer - they found a one hundred and eight inch micrometer.Holy Moly...
If you want to check your hole pattern then what about one of these, if dogs fit then you are square.I'm hoping that my routing skills with the RS template are good but an engineers square would put my worries to rest
yes and why not!I made a big layout triangle made from one section off a full sheet of MDF. My reckoning was the corners are more likely to be 90 degrees over that 4' length, or at least way way better than any other square that size.
Yes thats the way to do it - just heave-ho until it looks about OK!Yes well, this is plumb enough for me....... Come to think of it, I guess it's why nothing I make is square.
Top of wall plumbish to sole plate.
I had to shove it about a bit to get it spot on like that.....
An long edge strip from a sheet of MDF is a good starting point for making a zero clearance router fence as well.I made a big layout triangle made from one section off a full sheet of MDF. My reckoning was the corners are more likely to be 90 degrees over that 4' length, or at least way way better than any other square that size.
Working to within 1mm in woodwork is pointless as it moves with heat/cold /moistureyes and why not!
It's pretty easy to make up your own accurate square. I think the search for precision can be an attempt to make up for lack of technique - no point in marking a precise line if you can't cut to it, or don't know how to straighten it - a lot of woodwork involves covering your tracks!
Also a lot of work entails "offering up" to check for fit, and adjusting accordingly for a precise fit, not produced with squares or anything.
WRONG!!!Working to within 1mm in woodwork is pointless as it moves with heat/cold /moisture
The human eye is very good at judging if something is out, even by a tiny margin. If something looks, wrong it most likely is.Yes thats the way to do it - just heave-ho until it looks about OK!
I've had the problem of fitting doors and windows in little old houses where nothing is straight. Having to explain to the client that it'll look wrong if they are plumb vertical etc - they have to go with the flow!The human eye is very good at judging if something is out, even by a tiny margin. If something looks, wrong it most likely is.
In this instance I’d absolutely agree with Jacob, having worked many years on old industrial sites and projects, the last thing you want to do is get your work 100% square or level. Do it by eye or your work is the thing that looks out of square.I've had the problem of fitting doors and windows in little old houses where nothing is straight. Having to explain to the client that it'll look wrong if they are plumb vertical etc - they have to go with the flow!
