Woodpeckers Woodworking T-Square - 600mm is BACK IN STOCK!
Wood Workers Workshop
UKW Sponsor
16 Nov 2021
Threshing Barn, Upton-upon-Severn, Worcs WR8 0SN
The popular Woodpeckers Woodworking T-Square - 600mm is BACK IN STOCK! Now comes with the NEW and improved wall-mountable Rack-It™ to keep your precision t-square safe and always in plain sight.
Woodpeckers Woodworking T-Square will help you draw straight, accurate parallel and square lines in no time, instantly move your pencil from 1mm to 600mm and be dead-on with no need of a tape measure.
Each Woodpeckers T-Square consists of a laser engraved aluminium blade and precision machined beam, secured together with 6 stainless steel screws. A slight offset between the holes in the blade and the threads in the beam put the two under constant tension. This design delivers an angular precision of ±0.02 degrees. It delivers top-notch performance yet allows the blade to be replaced should it be damaged.
Now comes with the NEW and improved black metal wall-mountable Rack-It™ to keep your Precision T-square safe and always in plain sight.
ONLY £164.95
SHOP NOW
apiz5z0pj__42569.1638443871.jpg apiefvefe__08462.1638443872.jpg apifg24nk__44211.1638443870.jpg apidnuqno__91103.1638443873 (1).jpg api6aabje__30013.1638443875.jpg
FREE UK Delivery on all orders over £45.
We ship worldwide, duty and tax included - click here to find out more
If you have any questions or need any help our team of technical experts are always on hand to give advice, email us at [email protected]
I bought one of these a few years back for the simple reason you can set square yourself should it come out of it during use or being dropped. Lovely piece of kit.
