sams93
I think at best this loosely qualifies for this forum, in that the solution currently involves a piece of wood. I'm wondering if anyone has any ideas as solutions for my problem below.
I enjoy working on my car, but have a gravel driveway. Using a jack on gravel is a big no go, because the jack needs to be able to roll itself inwards towards the car on it's wheels as it moves up, and then retreat outwards when being let down. Every time I have to jack the car up, I use a 1m x 60cm sheet of painted 18mm plywood as a base for the jack to sit on. It mostly works sort of fine, but the plywood surface isn't hugely strong and the jack wheels are small, so the result is that sometimes it digs in to the plywood and then the wheels don't roll so the jack cannot move = not good. I've made do like this so far and it has been fine, but i'm wondering if there might be a better material, or something that I can stick to the face of the ply to stop this.
It needs to be cheap (ideally free... something I might readily find on facebook marketplace or the like), because I don't care about it very much and it just lives outside against the side wall all year. It also needs to not be harmful or messy by design (I thought of steel sheet but it will rust and then when i'm messing about under the car crawling around I will end up covered in rust myself).
Thoughts so far:
TIA for any suggestions...
Thoughts so far:
- Sheet steel 1-2mm - I thought I could screw some to the face of the boards.
- Will rust and cover me with rust when i'm under the car = no good.
- Will end up with sharp edges which will also lacerate me under the car = also no good.
- Sheet aluminium 1-2mm - could screw to face of boards.
- Will it be strong enough or will it just deform
- Same concern about the sharp edges which might lacerate me
although I suppose I could just grind them down.
- Some kind of plastic?
- It needs to not shatter and be strong enough not to break with the jack wheels.
- I could round the edges so that I don't get injured by it.
- Something else altogether?
