gasman
Thanks so much for all your suggestions
IN the end I decided to make a 1/3 model to see what was possible - and it was much more straightforward than I thought. I did it in some rough scraps of walnut and it is 22 inches long
I just did a halving joint which was easy, then marked out all the mitres carefully with pencil (will use marking knife for the real thing), then using a combination of the Bosch 10.8V multitool and the Bosch 10.8V sabre saw (have hardly used either) rough cut the mitred edges, finished with a rebate plane and chisels.
The back I have left that central square piece and just done the mitres on the limbs as I think it is a bit flimsy with the mitres cut right back
Thanks again
Mark
![7219687030_fa7990d534.jpg](https://proxy.imagearchive.com/197/197cd71645f7fc37cf5d7c85ce491fbb.jpg)
Thanks again
Mark
