Hi, I haven't post here for a while.
Decided to make use of some ash and sapele off-cuts left from a flooring/parquet job and had the idea of
making a bracelet (or indeed a set of bracelets) using a technique akin to segmented turning.
I opted to make the bracelet oval instead of round since I think it would fit better on the wrist.
First off, I used a cad program to help me draw the bracelet and figure out the relevant dimensions/angles for the segments.
I also used the drawing to build a set of templates for routing the shapes as shown further on.
A good source of how to approximate ellipses with circular arches can be found here:
http://www.thisiscarpentry.com/2012/02/ ... es-part-2/
The offcuts used came from bandsaw cuts and had to be thicknessed down to 5mm, so I used my spindle moulder,
doubling as a spindle sander and a sanding block and made several passes until I got to the desired
thickness:
The final batch:
Then I cut the segments on the sliding table of the saw bench. I used two mitre gauges to speed up the process
since, in an oval shape, each segment has different right and left angles:
Cutting such small pieces can be hazardous. I used the eraser side of a long pencil to hold down the piece while cutting (not shown):
After a session of cuts, the pieces are all organised and tagged:
I then proceeded to gluing up. Firstly, I assembled each layer. I used masking tape to hold the segments together:
After the glue had set for each layer, it was time to glue them together: I stacked the layers and
placed weights on top to keep all tight.
Here I'm using a template jig to hold the glued layers and a trimming bit to form the final shape:
The inner oval is done:
Now the outer one:
Finally the result after rounding over the outer edges and two coats of oil:
She got little uncertain on which one to wear:
![cad.png](https://proxy.imagearchive.com/cc9/cc974f7636956fae6e5c3631fea34f80.png)
thickness:
![WP_20180825_20_17_40_Rich.jpg](https://proxy.imagearchive.com/0bc/0bced7adc231260b787540dbd5739648.jpg)
The final batch:
![WP_20180825_20_19_59_Rich.jpg](https://proxy.imagearchive.com/52b/52b151bba5beb6737495faae1a624365.jpg)
![WP_20180831_08_52_17_Rich.jpg](https://proxy.imagearchive.com/5da/5da7b1dea75467706b585303da1c95a1.jpg)
![WP_20180831_08_53_03_Rich.jpg](https://proxy.imagearchive.com/810/810711b56607804c5d09d106a383ef19.jpg)
![WP_20180831_08_57_46_Rich.jpg](https://proxy.imagearchive.com/800/800440a84f884ef322421853a5f12320.jpg)
![WP_20180901_18_05_50_Rich.jpg](https://proxy.imagearchive.com/46b/46b4f86c246e0bc86c57d0b489695707.jpg)
![WP_20180902_18_07_35_Rich.jpg](https://proxy.imagearchive.com/879/879a2b0af3823080fd9a04b9d7bdb768.jpg)
![WP_20180906_09_01_05_Rich.jpg](https://proxy.imagearchive.com/5f3/5f3fbdbf65f0e8f3504b7ed808485a94.jpg)
![WP_20180906_09_05_23_Rich.jpg](https://proxy.imagearchive.com/2fb/2fb3695250d1fbfe4fb2f718b3c8a3b8.jpg)
Now the outer one:
![WP_20180907_09_12_17_Rich.jpg](https://proxy.imagearchive.com/1ee/1ee52566504a54602ed2611e20d4d123.jpg)
![WP_20180910_21_55_47_Rich.jpg](https://proxy.imagearchive.com/ef1/ef1c3b525cec7a827d71480439ca8c7e.jpg)
![IMG-20181006-WA0003.jpg](https://proxy.imagearchive.com/eb9/eb9b1a4a762ff7edbfd01a8d077dc9fa.jpg)
