Benchwayze
Hi folks :
I want castors for my Startrite 351 bandsaw, but it seems anything I could buy would have only two castors that can swivel. I prefer four swivelling wheels.
This morning, while tidying some off-cuts of 3 x 2 and 18mm MDF sheets, I had a :idea: moment. I remembered that the bottom of my saw is just a sheet steel box, with one open side, and an open top. It is just a void, where the dust falls to the deck, and I have to vacuum it all away every week. (When I am using the saw!)
There is nothing inside that is necessary to the saw. It's just bolted to the bottom of the saw itself. So, Instead of tidying up these off-cuts, every so often, could I use them to make a new bandsaw base altogether? I certainly have enough material. I also have four, 3 inch diameter swivelling, lockable castors lying idle in a cupboard.
I would use MDF for the panels and 3 x 2 for the frame. This might be heavier than the existing metal box the saw presently stands on; or maybe not. I know someone will probably point out, that I could just make a square castored frame and mount the whole thing on that. Unfortunately that would lift the machine up some 5 inches; meaning it would foul the rafters in the garage. Also I would need to make a duck-board to stand on, and I don't like duck boards!
Has anyone made a new base for their own saw, and if so, did you find the need to put any extra weight down below for ballast?
Thanks in anticipation
John
John
![](https://proxy.imagearchive.com/433/43349c2e7f064eb2c5e67c736c749df1.gif)
