Wood stove fans
Mine arrived. Vonhaus. £20
It seems to work, much the same as HC's above. Much stronger when the stove is hottest, and can feel the draught.
It's packed up. 3 months of use. Got instant refund no quibbles - I guess they are used to it.
Pity really because it did seem to work well and make quite a strong draught. Might try another brand.
Just noticed @johnyb 's post #41 about a tile to buffer the heat. Perhaps a good idea, too late now!
No connection but Hetas man coming on Friday to check the installation - checking the registered installer that is, to make sure he's followed the rules.
They use the heat to function, I believe it is a device working on the Peltier effect so no heat and no electricity. A Peltier works much like a thermocouple in that it requires a temperature difference to create a voltage so one hot side and a colder side to work.
