Hi everyone
Last November I built a set of gates for our drive. They're made from Scandanavian Redwood (softwood) which I bought from a farm up the road.
Each gates is constructed with a frame which is filled in with a row of vertical "slats". The slats were glued together to form a kind of closed panel. I finished the gates with some oak effect Cuprinol external wood paint.
In the new year when I fitted them they looked wonderful. However as the heat has risen throughout the year the slatted panels have shrunk big time. You can now see between most of them, and between some I can even fit my little finger!
I think that all of this is down to the wood shrinking but I just need to know what I should do next time I make some gates.
My gut feeling is that I should buy the timer elsewhere. If so how can I be sure the same thing won't happen again?
Should I be sealing the gates with something better than paint so that they can't expand or contract depending on the weather?
Can anyone offer some advise on this subject?
Many thanks, Andrew
Many thanks, Andrew
