Nigel Burden
Good diamond plates are expensive but, long term they work out cheaper than using sand paper/wet and dry paper which will tear and needs sticking to a flat surface. In fact, long term, diamond plates are probably the cheapest. Good quality oilstones are not cheap either, and water stones need flattening as they wear fairly quickly, and again, good one are not cheap.
As far as method is concerned, find one that is not complicated and stick to it. If, after perseverance it's not working, find another. Sharpening is an emotive subject and there are threads on this forum that are pages long. (hammer) It's what works for you, but have a look at two or three videos and give one a try. After all, you can only learn.
Nigel.
Nigel.
