Mdotflorida":1rkb1xst said:
I don't think I did offer blanket advice. I simply stated "I" always sticker.
True Jeff, you didn't offer your practice as blanket advice, but it could be implied from your original one line response that stickering per se is a 'good thing.'
You didn't give a reason why you always sticker. What's the benefit and what are the disadvantages of stickering up wood? It's not always a good idea to sticker timber-- see below.
Sgian Dubh":1rkb1xst said:
Therefore stickering the wood in your workshop may not be of any real benefit.
It may not offer a benifit but is there any harm. ? Jeff
There could be. Let's take a realistic scenario. Some timber is acquired that currently measures out at 8% MC. This is about the right MC for wood that is to go into a residential property in the UK, assuming good insulation and heating. A typical UK house will exhibit RH (relative humidity) values of about 40% in winter and about 60% in the summer. Household furniture in these conditions will swing between about 7% MC in winter and about 11% MC in the summer.
Wood at 8% MC as described above is at about the lower end of the range you'd expect it to experience in service. Edge joints (e.g., table tops) for one survive better as the wood expands (compression) compared to when they shrink (a tensile force.) So before making the piece of furniture you'd want to keep the wood as close to 8% MC as possible.
Now, if you take your 8% MC wood out to an unheated workshop in the UK with poor insulation, typically the RH will hover between about 65% and 85% as I described before. If the wood is stickered this facilitates moisture exchange so the wood will gain moisture, and this 65% to 85% RH range means the wood will settle out at somewhere between 13% and 18%, probaly at about 15% or 16% MC. These numbers are higher than internal furniture will experience, so stickering would be detrimental.
You'd be better to close stack the wood in the relatively damp workshop (if it's the case that you must store the wood there rather than in the house. Close stacking means that the boards at the centre of the pile will gain approximately 0.2% of moisture per four weeks. In theory then you could close stack wood that is 8% MC for about five months before it would rise to 9% MC. Of course the outside of the pile would be exposed to the higher RH conditions. Wrapping the wood tightly with plastic sheeting will reduce the speed of moisture gain here substantially.
What I've just written is no more than a summary of one possible scenario, and it fails to take into account a whole load of variations in circumstances, conditions and any exceptions that could have been discussed, but it does illustrate a situation where stickering a pile of wood would not perhaps be the best choice, and could even be extremely detrimental to the success of a project. Slainte.
