woodfarmer":2v4ho8ct said:As it happens I have a need to seal quite a lot of green pear wood and hopefully later walnut. Is this the right ( or at least a good thing to use?) if not can you recommend something better from screwfix.
gaz8521":a9p5g6ca said:I use A PVA sealer from B&Q which I put on neat, not the cheapest but it works for me
Gaz
woodfarmer":cfctpy25 said:gaz8521":cfctpy25 said:I use A PVA sealer from B&Q which I put on neat, not the cheapest but it works for me
Gaz
Thanks GAZ, but it has to come from screwfix as they will post to France.
bellringer":27z1izkx said:woodfarmer":27z1izkx said:gaz8521":27z1izkx said:I use A PVA sealer from B&Q which I put on neat, not the cheapest but it works for me
Gaz
using waste ends of candles is cheaper also you must be able to buy PVA glue in France
Woodmonkey":2byolr87 said:Look on eBay for wax pellets you can get 5kg for less than £20, that will do a lot of sealing.
