Slight problem with my wood cutting axe. Been working well for awhile. The problem now is the axe head and sleeve keep slipping down the handle. Bare in mind the handle is made of reinforced nylon and not a traditional wooden handle. Your thoughts?
pe2dave. Yes--thought about that. But being a 'reinforced nylon' shaft and not a wooden shaft could you put in a wedge?Wedge from shaft end into head?
If the handle is 'greasy' (soft nylon type?), then add some sticky either side of the shaft.pe2dave. Yes--thought about that. But being a 'reinforced nylon' shaft and not a wooden shaft could you put in a wedge?
