user 42596
- Joined
- 22 Jul 2023
- Messages
- 488
- Reaction score
- 596
Don't swing right at the middle of the log, take bits off the edges, working your way around the log, but yes, Lime is a tough one to split.
A point about light weight woods - it's good to have the biggest stove you can sensibly fit into the space i.e. much higher rated output than the room calculations say is needed. Then you can burn smaller fires but hotter, including getting heat from "light" woods.Lime is wet...and cut rings in the rain get even wetter. Turn them on edge and cover for a couple of months; then try again. It should split nicely, even though the wood isn't great for burning too light so takes a lot of space, and burns rather cold)
All stove fitters and suppliers will tell you the opposite - work out the output needed then go one smaller. This is so you don't end up with small fires in a large stove for much of the season.A point about light weight woods - it's good to have the biggest stove you can sensibly fit into the space i.e. much higher rated output than the room calculations say is needed.
Small fires in a large stove are much more efficient than the opposite, for the reasons stated above.All stove fitters and suppliers will tell you the opposite - work out the output needed then go one smaller. This is so you don't end up with small fires in a large stove for much of the season.
I would take it too, chop it into smaller chunks and mix it in with other woods, by the end of the night its gone. and that heat was free.Lime used to be used for brake blocks on horse drawn carts as it smouldered rather than bursting into flames. That said, take it and mix it with other timbers.
So major stove suppliers and qualified stove fitters are all wrong?Small fires in a large stove are much more efficient than the opposite, for the reasons stated above.
Yes. If that's what they all say, but I don't suppose they do.So major stove suppliers and qualified stove fitters are all wrong?
Exactly the opposite. Small fire, big stove, means more air to the fire for hotter cleaner burning, and also larger radiant surface area of stove itself.Yes, that is what they say, but they obviously haven't consulted you. It makes perfect sense, as they explained. A hot fire in a small stove is far more efficient and much cleaner and better for pollution than a small fire in a large stove.
Exactly. Especially if you want a rapid warm up almost any time of year.For a handful of days a year you might wish you had a bigger stove
No it's worse.but for the rest of the year it's better.
Nobody trying sell me a stove, I make my own mind up. I've been at it for some time and made a few mistakes. Worst was Morso Squirrel which was too small and needed frequent maintenance, bricks, baffle, etc.As a matter of interest - why would the person trying to sell you a stove try to sell you a cheaper one?
Yes it would seem so.As usual, Jacob knows more that people who do something for a living.
So you think that the laws of thermodynamics have no relevance.......Exactly the opposite. Small fire, big stove, means more air to the fire for hotter cleaner burning, and also larger radiant surface area of stove itself.
No it's worse.
Yes but a tiny amount of heat compared to the throughput and it all finds its way back into the room when the fire goes out - so zero sum.So you think that the laws of thermodynamics have no relevance.......
Did it occur to you that the bigger the stove, the more steel to be heated...........??
No connection or resemblance at all to a wood stove.According to your logic every radiator ever made should be the size of the wall its fitted to......
Yes you are! Don't worry about it you are not alone!.
Bonkers.....
Dowling. Dowling Stoves - Home@Jacob - perhaps you've already said in other threads, but do you mind if I ask what stove you have and/or what stoves you recommend, in terms of make/model? Many thanks
