ThornOfCamorr
Hello,
I'm very much at the beginning of my woodturning journey, so this might be a very stupid question...
I've sharpened my roughing gauge (got it 2nd hand) on the grinder using the oneway wolverine jig. I got a sharp edge, but I failed to grind it "square across". The tips left and right are of the same height and that runs perpendicular to the flute, but "middle" of the edge is shorter than the tips (kinda a bit like an inverse fingernail profile). Apologies for describing this clumsily, please refer to the pictures. I also noticed that the flute is not square to the handle.
I used the tool on the lathe and it cut brilliantly, although i had the feeling once tilting the flute to the side that the tips engaged more heavily, making it more prone to catches (I had a few, but all very controlled and not dangerous - this ofc can also be due to me still figuring out what I'm doing). I do wonder if the geometry of my tool's blade is the problem here.
I've looked at a few youtube videos on how to use the wolverine jig, but can't notice anything I'm doing different. On question here is: when grinding and turning the tool, do you aim to always grind in the center of the wheel or does that turning motion also mean you turn more on the left/right of the wheel?
I hope my question makes sense and I'm looking forward to your enlightening advice.
