Rhyolith
Its finished! and lubed it up with NUTO 32.
1950s Wolf TG6 Grinder by Rhyolith, on Flickr
I decided to use this frame i had lying around as a stand, actually its a big improvement as its not using up space of the bench anymore:
R0000006 by Rhyolith, on Flickr
Its a lot smoother than before I think using the other spindle has made the difference. Theres still a bit of vibration as it decelerates, but not much.
Video of it running:
1950s Wolf TG6 Grinder Running by Rhyolith, on Flickr
One thing I am not sure whether it should be worried about is the horizontal play in the spindle, it moves side to side a bit, not sure if this is normal. It likes to ride fully to the right when turned on.
R0000002 by Rhyolith, on Flickr
I am actually a bit mystified where the play comes from, all the bearings fit quite tightly... must between the housing and the outside of the bearing I think.
