Hi all
Some years ago I took apart a defunct B&Q table saw as it was dead. I kept the NVR switch as I thought it might come in handy one day. Well, that day has come. I'm working on a router table wing to go in my table saw and want to use the NVR switch for a bit of added safety. Unfortunately I didn't know what I was doing when I took the switch out of the table saw and I need help reconnecting it.
I've got the input and output wires but they are not connected in the switch and I'm not sure how to connect a double plug to the output side of the switch to plug my router and vac into as it is 5 strand cable - maybe I can't use it?
Still here goes...
Pic 1 is a general shot of the switch
There is reset switch wired in on the input side and a yellow box which I have no clue about as shown in Pic 2
The six ends of cable have to be connected to the switch in Pic 3
There is a wiring diagram on the switch:
which seems to suggest that the cables from the yellow box are connected to pins 2 and 4 but I have no idea which wire goes on which pin or which wire connects opposite them.
I've drawn a diagram - can anyone help with the connections in the switch and the connections to the double plug?
...or tell me if this switch can't be connected to a double plug as it is designed to be connected to a motor!
Still here goes...
![DSC_0094.jpg](https://proxy.imagearchive.com/c35/c35d4517855be035474d7c3265fa1ec4.jpg)
![DSC_0095.jpg](https://proxy.imagearchive.com/d7f/d7f466d5d586973b4b6e1cead34ab902.jpg)
![DSC_0096.jpg](https://proxy.imagearchive.com/24e/24e952480fb138c0eea0aaf84a26326e.jpg)
![DSC_0099cu.jpg](https://proxy.imagearchive.com/689/6899f6a8a604358373ff9bbc7962c9b4.jpg)
![DSC_0097ed.jpg](https://proxy.imagearchive.com/731/731aeeaa03ce3ae0ad74d183eacc8dd7.jpg)
