Frank House
The setup I have has been running for nearly 20 years has a single 'zone' for the whole (large) house.
As Steve said, the boiler automatically switches according to demand, it keeps the pipes close to it hot at all times, not a big cost if they are well lagged.
I set it up as an ongoing DIY project over several years, easily done room by room.
Simple 'on-radiator' TRVs for hallways, stairs, rarely used rooms etc.
For nearly all other rooms, I use programmable thermostats placed to sense temperature at shoulder height in a suitable spot and electrically operated controllers ("valves") on the radiators.
The radiators all seem to have a 'standard' fitting which includes the needle valve which actually governs flow. Just unscrew whatever controls it (casually described as the "valve", controller would be a better term) and screw on a TRV or electrically actuated "valve". No need to drain radiator or system for this.
The thermostats I use are by SALUS, just because that is what I tried first, their cost is (at least was) reasonable, and they have all worked so far.
For each room, one can choose wired or wireless connection as convenient. Wireless connections are coded to avoid crosstalk.
The thermostats I use need a couple of AA cells. They last for years and are easy to replace. Caution -- some makes of thermostats have built in batteries which are not replaceable, and the unit must be discarded when these pack up.
For wired connection the thermostat is connected to the mains, and a cable run to the radiator. For wireless use the thermostat's battery suffices, and the receiver unit is plugged (or wired) into a nearby mains supply and controls the radiator "valve".
With a bit of luck there should be no need to lift floors or make (large) holes in walls.
To meet current wiring regulations, radiators should be earthed, and any "wiring in" should be handled by a qualified electrician. Given that, it need not be a big job. It is quite practical to DIY and get it checked, so labour costs need not be huge. George B mentions battery powered actuators, no personal experience, but that would mean no mains connections at all and an entirely DIY setup
Decent thermostats should have a "holiday" setting -- just one button press. That is as "smart" as I want to get. Not interested in phoning home to get the system running for my arrival, never felt the lack. Makers can be mixed -- no need to pay for a "system". No need for anything to be online, good reasons not to be.
I am NOT an expert -- no responsibility accepted for wet carpets, domestic stress etc.
As for cost, we noticed no great change over the few years the system was introduced, but a great reduction in the hassle of adjusting radiators, particularly when family visit. I reckon that performance (i.e. comfort, cost, and convenience) at the present level would be hard to achieve with manual "valves" only.
Frank.
Frank.
