Crooked Tree
Plan: build a proper workbench to take over from the workmate. The bench must be/have:
- sufficiently heavy and rigid that I don't need to stand on it whilst planing
- flat (unlike the workmate)
- fitted with both a front and an end vice
- lots of clamping opportunities... one of my greatest issues has been holding work still!
The design has been evolving over the past 6-9 months... it was originally going to have a full width end vice, then a tail vice and finally I decided that a wagon vice should be easier for me to make with limited skill and yet still end up with something that is not "wobbly". It will use an off-the-shelf vice screw. The front vice will be a second hand ready-made iron one, for simplicity. The top will have no apron, to allow for easy clamping to the top. If it proves to flex too much then additional beams will be laminated underneath to stiffen it.
The design was influenced by the small Roubo workbench made by Boz62 a couple of years back in that it uses a length of beech worktop cut in half and laminated to make a slab more easily than doing it myself from scratch (no planer or thicknesser). I used a thinner worktop section, though, and was still only just able to lift it! The end result will not be in any particular style.
So, starting some months ago:
Ordered the worktop, which was delivered in quick time. The worktop as delivered
The worktop had a number of small defects in its surface, and had a small step or two in the surface, presumably arising at the manufacturing stage (the packaging was intact) e.g
Not sure if this is considered normal for worktop, but if it were for use in a kitchen they would need filling. However, it was fit for purpose as a workbench, so I used it rather than delay by trying to return it.
Cutting it into two pieces, each ~ 1500mm long
Next it was laminated to itself using Evostick and too few clamps/insufficiently rigid clamping cauls - I hope that with such a large gluing area it should be ok anyway.
The edges of the slab were then planed square.
The base/underframe is to be of the knock-down variety using 2 end trestles and rails between them. I decided to use 2 smaller rails, top and bottom at both front and back to allow for a shelf/storage and possibly a sliding deadman.
Base materials - bandsawn beech, some 2" before planing for the legs and some 1" for the rails. 2 pieces of 1", each 2' long had to be cut off to get the boards into the car. These will become the upper short rails of the trestles.
There followed much planing using my trusty Record No.5, sometimes very finely set to cope with awkward grain.
To be continued... not at the present day yet.
