This is slightly below the usual standard on here, but what the ****.
Fresh from the logpile and split in half. (Does anyone know the wood?)
Planked and thicknessed. (Axe and electric hand planer respectively)
My first ever glueup! I trueished the edges two at a time with my only hand plane - a record #5, I think. The boards were vaguely the same thickness, but I intended to flatten them properly after glueing them together. I have a feeling this is backwards, but worked out ok. The inset is a bit of teak for the handle support.
My first ever dovetail cut and dry fitted.
The handle support has been shaped and is being glued into the end. You can see how rough the finish was in the glued up end waiting on the right.
A finished end: planed, sanded and oiled. A few gaps around the dovetail were filled with glue and sawdust.
Another first: a wedged tenon. (Both the wedge and the tenon)
The handle attached to both ends, and the first rail in place.
It was slightly tricky getting the tenons square with that handle. In retrospect I quite like the different heights.
The teak was from some old benches from my local sailing club, the oak handle from the woods nearby, the oak rail from an old set of shelves I've had for the last 15 years, and the wood for the ends was from the logpile.
Now to find enough time to finish it off.
