AES
As we all know, the as-delivered tables on vertical drill presses tend to be somewhat small for wood working and I’ve been thinking about combining an add-on wood worker’s drilling table and a drum sander fixture to my drill press for some time. My new “combi-table” is an amalgam of ideas I’ve found around the net (especially on this Forum of course) and apart from the sanding drum lower bearing support feature, which may be a unique idea, there’s very little original AES thinking here.
The idea was to have one table that can be easily used for both normal drilling and for contour sanding with nil or minimal changes between each mode, and with decent DE (dust extraction) in each mode.
Here’s the new combi-table in contour sanding (Picture 1) and in “normal” drilling modes (Pictures 2 and 3):
The pillar drill is a cheap Rexon 12-speed model (210 to 2,580 rpm), 13 mm (1/2+ inch) capacity, 800 W. It has dual belt drive, so changing speeds is a bit of a fiddle, especially as it’s mounted on the bench, bringing the drive belts up above eye level. I knew that this would be inconvenient when I bought it but as I couldn’t afford an electronic or gearbox model at the time I decided I would have to live with it. It’s OK in practice – mostly it stays set at about mid-speed anyway.
As I also do some metal working I thought about making the combi-table easily removable, but in the end decided not to bother. I think that just by removing the fence if a metal work piece size dictates, it’ll be quite possible to use this table for metalworking too.
Picture 4 shows the cast iron table on the pillar drill as it was delivered, plus the 4 off 8 mm (3/8th inch) dia holes I drilled & tapped behind and in front of the existing 45 degree slots. It’s easy enough to remove the 4 bolts to revert to the original cast iron table if ever necessary.
It was also necessary to slightly shorten the arm of the existing table raising/lowering crank handle to provide hand clearance under the new combi-table. This is simply a piece of scrap 3 mm (1/8th inch) MS plate (Picture 5):
Nothing in the construction is particularly clever or difficult, and no wood or metal parts are anything other than scrap, except for some 100 mm x 8 mm (4 inches x 5/8th inch) coach bolts used as spindles for the sanding drums, plus a 1 Metre (3 feet 3 inches) length of 25 mm (1 inch) ID smooth bore flexible plastic hose for the through/under-table part of the DE. The only other specially-bought items were the T track and the Jigs Kit (knobs & T bolts) from Axminster Tools, but these do of course provide materials for many other projects. And Yes, I do have a small metal working lathe, but nothing seen here makes a lathe essential – it just makes things a bit easier and quicker perhaps.
The basis of the whole thing is a screwed and glued “tray” of off-cuts from 12 mm (1/2 inch) plastic-coated ply (smooth black outside, grey “bobble finish” inside). Basic dimensions are 400 mm (15¾ inches) wide x 295 mm (11¾ inches front to back) x 75 mm (2¾ inches) high overall. This includes 2 laminations of 8 mm (5/8th inch) thick MDF for the top surface. The “wings” extend outwards on each side by about 150 mm each, so bringing the usable table width from 400 mm to 710 mm (approx 28 inches). Picture 6:
{to be continued}
AES
{to be continued}
AES
