Melinda_dd
As a fello B & D workmate wood worker I would like to congratulate you on your box. It's hard to make "Pretty" and "Quality" with the set up we have, but you seem to have done a grand job mate.
Noel":ikeubox3 said:Mr 71, he of the reasoned and polite criticism, has gone the way of many Norwegian Blues, ceased to be, expired.
He had been warned before for a similar infraction.
clewlowm":1fhv5ynp said:well i like the idea of the box! i just think you could have perhaps thinned it down a bit? it does look heavy and cumbersome!
i also think that someone with as much skill as what you say you have? could have done a slightly higher standard of work. no malice intended simon.
joiner_sim":1jodumfz said:It is exactly how I wanted it, apart from only wishing I could have used thinner timber.
joiner_sim":1z6zlsmw said:I had to use 17mm timber, as the hardware I had available to me required fixing to the box, mainly the catch, and I could only find 15mm veneer pins to fix it with. If I could have sourced something smaller the timber would have been also thinner. Really I would have liked to have a maximum thickness of 13mm.
