OK. After some sabotage by a work colleague (LIAM!) my wife and kids have clearly directed me to have a bash at the Colibri plan. So, I ordered it on line, and the PDFs arrived by email in no time flat.
So, this is the still of what I'm attempting to make (although the link to Derek Hugger's page, above, has a video too).
I must say the plans (the PDFs) appear to be very clear - with the most comprehensive assembly instructions (31 pages of them) that I've seen - a sequence which the item should be assembled in. Given the number of parts, I think they will be pretty damn useful.
Anyway, first problem, as always, is printing the thing off.
I'm afraid I cheated a little, and chose to print off on a business lazer printer, rather than a domestic ink jet printer (shhhh - don't tell my work!). The originals are in American paper sizes, but as long as you don't ask for any form of scaling, they seem to come out fine, as none of the parts are so close to the edge of the american sized paper to cause a problem when printed on A3/A4 paper. Each page of the plans with full-scale diagram on have a scale at the top, so you can tell whether the hard copy is to scale in that direction, by just popping a ruler on top. That doesn't, however, allow you to check the other direction.
What i mean by that is my experience of producing hard copy or indeed photocopying, on laser printers is that in the direction the print head / drum lies, the hardcopy have an accurate rendering - because that is fixed in the construction of the printing mechanism. However the other direction is all about how fast the paper 'rolls' past the print head relative to the speed it should be - and that can vary between printers. Its difficult to check that error out so I did a separate test printout (printing the same item out on landscape paper then portrait paper, and compared the two). that showed I had an error that was visible, but less than 1/2 mm over the length of the page. I felt that was reasonable.
(I did email Derek and suggested he put a scale on the long paper direction too, for this reason. He emailed back very quickly saying he thought that was a great idea and would add it on the next iteration of the plans and new plans).
So, there are three sections to the PDF:
* Introduction page - on how the sculpture came about.
* General instructions and parts list (maybe 10 pages)
* Scale parts patterns (17 pages A4)
* Assembly instructions (31 pages
+ Separate PDF of 6 A3 pages (well the american size, but you need to print them on A3).
So far so good.
Now, looking at the parts list was the first issue - do I do it in Imperial (which it obviously is expressed in) or metric.
BIG DECISION
I know I can get things like copper tubes and rods in both easily enough, but the sculpture calls for some pretty involved metal parts. It gives a source in the USA (complete with part numbers) but they won't ship abroad (the plans warn about that). However, I do have relations in USA who could take delivery and repackage and send them on to me, so that's not a blocker.
Adding up all the parts, from the USA supplier - to see it comes to about $200. Bit shocked at that, although that's probably well under £1 an hour for the entertainment time it will be
So, I'm going for imperial, so all the slots and hole sizes in the plans can be used as is.
I've sourced the tubing and rods in the UK (brass, aluminium, steel) from a great supplier -
http://www.glrkennins.co.uk - very quick and good prices. Just online mind you, but that suites me fine.
First I need to decide on the wood for the humming bird itself. The picture uses the approach of making the bird and flower stand out by making it out of a contrasting dark wood. I think that looks good, so I've tried to use some left over mahogany (very dry, left over from a grand father clock case i made over 20 years ago!).
I needed some 1/8 inch thick section and some 1/4.
Resaw the blank, and using thicknesser I should be able to take it down to 1/8. Of course the thicknesser won't actually go down that far, so I have to use a false table. However, I found that the grain wasn't flat enough, so once I got to about 3/16th, the 'plank' started to break up - just too much catching on the grain
OK. that will do for now, at least I've started, and this forum will make sure I keep the momentum going
BYE FOR NOW
