Which SCMS budget £250
TonyW
10 Jan 2007
Cheshire
Have scoured the forum (and even asked this question on my first post) for advice with a first SCMS - only now am I ready to purchase.
I am now totally confused on specs. and best buy for my limited budget of £250. I suppose it would help to define precisely what I want to do with it - in the first instance a couple of simple jobs - cutting laminate flooring and building a couple of wooden decks - for which I guess that virtually any chop saw would suffice. As to future projects I am unsure of where my interest may take me.
Currently I am thinking of either Ryobi or DeWalt with the following specs:
DeWalt 707...........................Ryobi EMS 2026SCL
1200 Watts..........................2000 watts.....Power Input
6700 rpm.............................4500 rpm .....Blade Speed
216 mm...............................254mm .....Blade Diameter
48 °.....................................? .....Bevel Capacity
50/50 ° ...............................? ..... Mitre Capacity [right/left]
60 mm................................90mm .....Max. Depth of Cut
190x60 mm.........................215 x 90 .....Cutting Capacity at 45°/90°
270x48 mm.........................305 x 42 .....Cutting Capacity at 90°/45°
270x60 mm.........................305 x 90 .....Cutting Capacity at 90°/90°
190x48 mm.........................215 x 42 .....Max. Cutting Capacity at 45°/45°[/b]
I suspect that I may be getting a little too carried away looking at specifications. On the one hand the Ryobi seems to score larger capacity motor and cutting capability. On the other the name DeWalt - is this a much better machine - accuracy, repeatability, etc? I was once told "If you are going to have one have a big un" :D
Both units are available including stand within my budget.
So I would appreciate any comments, suggestions etc. (including any alternatives that sit within budget).
Thanks in advance
Tony
DeWalt all the way,
WHilst the capacities on the Ryobi might be slightly better, i'm sure the accuracy of the Dewalt will be a lot better.
I have one I use on site and its great. The leg kit that it comes with is pretty reasonable too.
The adjustment for the mitre angles is simple too, the locating plate is fixed with screws, but the holes in the plate are slotted to allow adjustment.
In the 3 years I have been using mine, I have only needed to adjust it once
If the depth of cut (60mm) will suit the sort of work you will be doing in the future then I agree with Matt go for the Dewalt. I have the 718 and it is a brilliant saw, so I have no doubt that the 707 is too.
Mike
One or two other things to mention. The Dewalt doesnt have bars poking out the back and so is easy to place on a bench without sticking out a mile and more significantly is that the dust extraction kit you can get for one is very effective whereas for most SCMS' it is crap, a real bonus. Don't be decieved by the apparently smaller motor size,it is very punchyand more than man enough. MTS power of northampton have the 707 on offer for about £230 IIRC at the mo, a real steal considering the first one I ever bought cost me over £500 as the ELU PS274 ( same machine rebranded). The icing on the cake for me is the excellent bevel mechanism that makes awkward skirting mitres a breeze because you pull out a pin to go over 45'. I will still replace mine with another.
Regards
Andy
woodbutcher,
Could you check the link you have posted? :-k
It appears to be a company offering tools to process data, not wood. :whistle:
I use a Dewalt 708 and have had it for years never let me down, Dewalt all the way!
Thanks for the replies and opinions.
Just got back from a trip to MachineMart (just to have a look!). Looked at the Ryobi - much bigger machine than I thought - Andy made a good point about the bars poking out at the back! Did not have the 707 on display though to compare. Another machine caught my eye - one of the Makita models. Looked good build with positive presets although not a sliding unit. Have looked at the prices of Makita SCMS and realised way outside my budget.
Philly will have a good look at the Axminster - pity they do not have a showroom in Cheshire!
So far I think I am being drawn to the DeWalt - although I do not like the marketing ploy of suggesting list price of unit over £800 therefore massive savings!!
Cheers :D
Tony
The Dewalt DW700, 701 and 707 are some of the best saw's on the market in my opinion, we have two 707's and an Elu at work and when they come to the end of their life, they will be replaced with the same again.
Jonathan.
sorry folks for posting the wrong link :oops: :oops: :oops:
thank's woody alan for posting the right link it was late at night and my eyes were playing up due to evaporating liquid. :lol: :lol:
woodbutcher
Philly":3k7c0r16 said:
Tony
I've had this one for a while and it is fantastic. Quiet induction motor and brake, too!!!!
http://www.axminster.co.uk/product-Axmi ... -32404.htm
Philly :D
Philly - are you still pleased with the Ax slide mitre saw? I'm looking for a crosscut/mitre saw to build a deck, and later a shed, and as I've got an Axmister £80 gift voucher to spend it needs to be something they have in stock. Don't anticipate using it for precision furniture making, just basic joinery. I shall put it on a wheeled stand and use it outside, so noise is a consideration.
Roger, hope you don't mind me butting in - I know the question directed to Philly.
Just to finish what I started I ended up with the DeWalt 707 and am very happy with it so far. I was very tempted to go for the Ax. after Phillys rec. not sure why I went Dewalt - maybe price or even the name.
Cheers :D
Tony
Thanks Tony. I quite like the look of the DW - had a play with a 712 in B&Q yesterday. Very nice piece of kit. Bit more than I wanted to spend, and as I have already overspent on the decking materials I may just make a cross cut jig for my hand held circular saw and save my money for the time being. But still interested to hear what Philly has to say about the axminster offering.
Roger, the price of the Dw does seem to have gone up since I purchased (paid around £200 incl stand and delivery) cheapest I have spotted on the web. is around £230 - what is the price at B&Q?
I suspect Philly not seen this post or possibly ignored it as it is an old thread. Might be worth starting a new thread about the axminster, or pm Philly :D
Good luck with your choice
Cheers :D
Tony
