weewilly123
New member
Hello all
This is my first post so go easy on me!
After some advice/opinions on which PVA to use.
I currently have a t&g engineered wood flooring in my hallway but we have a new extension and i am going to replace the current hallway stuff so it matches the new room and flows through..
Currently the existing floor makes a crackley sound when walked on - like the bond is broken - Im not sure if this is down to the pva used previously or if all engineered setups do this? I'm thinking is there a stronger PVA glue or a different typeof glue to use and if any of you have an opinion on which one would be best? Each flooring supplier just seems to push their own manufacturer of glue that they have a supply contract with but i would like an unbiased opinion if possible, which is seemingly hard to obtain!
Current floor is (14/3mm t&g oak flotaing floor with the T&G's glued with "no nonsense" pva on top of a concrete floor with 5mm foam gold backed underlay dpm).
Any help much appreciated.
