I'm looking to purchase several hand planes (used vintage record/stanley) to be able to tackle various projects and to be able to do 95% of the work with handtools
I currently got a £8 record no4 which I'm planing to convert to be a scrub plane (camber the blade/widen the mouth).
This is my plan so far:
- for the first step -rapid stock removal and general roughing up/shaping I will have the no4 record scrubber
-Than to start level everything properly I'm thinking about purchasing a no5 or no 5.5 jackplane?
- Than For jointing large pieces I'm looking to purchase a no7
-And finally I need something for smoothing out and finishing Like a no3 or no4? I'm not really sure what kind of plane would be the best for this step or even if I need a smaller plane if I will already have a no5? what would you suggest?
-Also I plan to purchase an old record/stanley no80 cabinet scraper to almost replace my sander with so I need to sand as little as possible.
I will be mostly using the handplanes to finish 3ft-7ft long boards.
What do you think about my plan? What should I change or add or remove from the list?
I would like to have as little tools as possible, but still have everything I need to do everything properly without faffing around.
