Afternoon all, I have a small 6x3m workshop and need to extract from a bandsaw with 2x100mm ports and a router table with an Incra cleansweep box (100mm port.) Chop saw and sanders/tracksaw currently using Festool extractors. In the future I will need to extract from a lunchbox planer to also use as a jointer with a sled (don't have space for a planer/thicknesser really.
Trying to decide between:
AW153E workshop range with optional fine filter - 1.5kw - 2,000 m³/hr @ 100mm with cloth bag, presume less if i add the fine filter, but how much?
AW118CE CYCLONE workshop range has fine filter - 1.5kw - 1,390 m³/hr @ 100 mm - takes up a bit more space
AP60E Professional range has fine filter - only 750w - 850 m³/hr @ 100 mm
The workshop ones seem to have 1.5kw motors compared to the similarly priced Professional ones with 750w. Presumably the money on the professional range goes into better build which i should be ok with as this is just a hobby environnment.
Wonder if anyone has had to make a similar choice or has any of these machines?
Dave
Dave
