I'm a hobby woodworker with a fully-enclosed basement shop, which was designed around a dust extraction system. At the time, I used a 3HP blower assembly, Oneida Super Dust Deputy Steel 5-inch cyclone, two Wynn MERV-15 canister filters, a 35-gallon plastic bin, and 120mm steel ducting with blast gates.
This is the enclosed dust extraction closet showing the heart of the system.
This are some images of the ducting as I was building the shop.
I am confident that my dust extraction system can be better, so I am replacing the 5-inch steel Super Dust Deputy (SDD) with the 6-inch Oneida Super Dust Deputy XL (SDD-XL). The 5-inch SDD is designed for blowers up to 3HP, while the SDD-XL is designed for blowers rated for 3-5HP. I will also be replacing the 120mm ducting with 160mm ducting and will only reduce to the machine port at the machine.
I bought my SDD-XL from Toolovation, and Martin was great to work with. Since the SDD-XL is larger than the SDD, I had to build a custom 35-gallon box using 19mm plywood. The platform holding the SDD will be lowered since I can't raise the blower assembly, so the plastic bin will be excess.
I will also take the time to fix design errors in my system and hopefully improve the flow.
