That suggestion would certainly give you a wide selection of auxiliary jaws to choose from (80 & 100mm aux. jaws all fit the carriers) and the axminster chucks are a commom standard throughout the range should you change your lathe or add alternate axminster chucks in future.Dave Brookes":1mr1nk6v said:I would suggest the Axminster SK100 with ‘C’ jaws as a starter.
Dave
The stepped jaws in metal chucks don't hold wood very well. They will rotate it but won't accept much sideways pressure. Thus only recommended for short lengths (say up to 75mm) which don't protrude too far from the jaws or longer lengths with tailstock support.memzey":1e9rshhm said:Can most chucks be used with wood and metal?
Before anyone can advise on chucks, we need to know:-memzey":2j0yuh6s said:if one were to have a single chuck to be used 80% for wood and 20% for metal, which chuck would you choose and why?
Yes, as long as it's a 4 Jaw self centring chuck.memzey":146p5afs said:Are you saying that it’s possible to use the same chuck for turning wood and metal by changing the jaws on said chuck?
Thanks again. So would this chuck fit the bill?CHJ":1hrotw0d said:Yes, as long as it's a 4 Jaw self centring chuck.memzey":1hrotw0d said:Are you saying that it’s possible to use the same chuck for turning wood and metal by changing the jaws on said chuck?
Three jaw chucks don't have wood specific axcessory jaws and are poor at holding in compressible wood.
Metal work of any significance on a wood lathe is limited to softer alloys with hand tools.
If you are considering being able to use any given chuck on both wood and metal working lathes then you are more than likely to have to go for a Versa Chuck style unit that has interchangable ISO back plates, it is most unlikely to get machines from the two disciplines with compatible spindle threads.
