That sounds like the best result possible (as it's about the easiest thing to change!).zeroseven":22o41yc5 said:It was the blade. The Sabrecut goes through an 11" log with no deviation.
Always check a new blade after installing. I've never rechecked an installed blade - I guess it might change, but hopefully not enough to matter (i.e. if it's changed a lot it's because the blade is worn and just needs replacing).zeroseven":14dj5k42 said:Thanks Sploo, I tested a while ago and didn't register any drift but will check again.
