CStanford":2v0vmevs said:
David, I'm seeing what I'm seeing and you always have some excuse. The cap iron article without a payoff photo of the completely planed board and now the video whose purpose it to show how to set a cap iron and then use the plane. Ash isn't always the easiest species to plane, I'll grant you that, but the piece you were planing didn't look that bad in the portions of the video that showed the grain of the wood. That video in no way, shape, or form shows a competent effort in wielding a hand plane on any species. It just doesn't.
Why wouldn't you have planed the piece ready for the smoother before you shot the video? None of this makes sense, just like the bit about the Woodcentral article makes no sense. Somebody was in a hurry, a crucial part of the process was done haphazardly or not at all -- makes no sense.
Go look at the other video I referenced, Charlie. I take one take on a video because I expect to take the video, upload it and be done. Not take several hours taking various takes. I don't remember what the problem was with that stick, but it probably wasn't that straight because it was an offcut. If I did a second take, I would've set the cap iron slightly less far back, but I was guarding against tearout and in combination with that taking the thickest shaving I could take with the setting so that nobody would say "that looks like a thousandth and you won't get tearout with a shaving that thin, anyway, because it doesn't have enough strength to lift". I'm pretty sure I said that in the video somewhere.
In the context of a piece of dimensioned wood that is fresh and straight, I've planed still much thicker shavings than you'd finish plane on quartered beech in the video I referenced. You can go look at it, perhaps it's a more accurate display of smoothing than picking up a piece of ash that was a table saw offcut and that had a couple of months to twist or do whatever. I expect you'll twist this some other way, too, but go ahead, Charlie. I haven't ever learned anything from you, and I don't expect that will change.
I don't have this insecurity that you must have where I am afraid of any possible criticism from something, or the need to go back and keep correcting. If I was that insecure, I'd take the other video down, but what am I afraid of - peoples' judgement? Come on. What I would be afraid of is spending hours and hours making videos if I didn't take them in one take, something that you may notice, I don't have any ad revenue turned on, and by far the biggest point of the channel has been documenting how the inside parts of a double iron plane are laid out and made. That's done, and I don't have much else to prove.
Same deal with the article which probably took a combined write and edit time of 8 hours. I'm not going to spend another 8 arguing with people to make it perfect. Anyone who wants the information can take it and run with it, and plenty of people have.
You want to add something positive to the discussion, I'll respond from now on. You want to cherry pick stuff from me and propose fallacies, then I won't.
