What's that finishing system called?
Fat Rich
8 May 2014
Detling, Maidstone, Kent
I was reading a while back about mention of a finishing wax or system that gives a plasticy looking finish in some peoples opinion. High gloss finish. Can remember what it's called to search for it.
I'd like to get it to give it a try on a lovely grained piece of coco bolo
Hard wax oil? You can get a small can through Axminster now, Chestnut do it.
None if those.
it was being discussed fairly recently after someone posted a pic with a fairly glossy finish and someone else said they wanted to get a finish system and named it
You can get a high gloss finish with CA (superglue) if it's a smallish turning. Widely used on pens which is what I use it for though I've no experience of larger items.
Plenty of info around if you look. Youtube as well has loads.
Bob
I'm guessing you mean the buffing systems and KimG's pieces? That's been the most prominent finish of that kind shown on the forum recently.
I would guess the results are the same, whether Beall or Chestnut. They mount differently if I recall correctly,
If you check out the pdf that Chas linked to Rich, that shows the use of Chestnut's Acrylic lacquer combined with the Chestnut buffing system as a means to achieve a gloss, it doesn't tend to look plastic though unless you overdo the layers, I find 3 coats are usually adequate. I use that system mainly for my coloured work, and the multicoloured at that as I am progressing the use of Shellac for non coloured and single tone work, I find that shellac gives an excellent glass like gloss while retaining completely the natural look of the wood, not in the least bit plastic, but quite time consuming to apply and it has it's own attendant problems of course.
